I have this issue come up now and again and I'd like to be able to solve it. But I frequently get excel spreadsheets that neet to be mached to a Point Layer in SDE. Normally I take the geometry of the SDE layer and keep the attributes of the spreadsheet. I normally use the FeatureMerger transformer. My problem is sometimes the number I use to match on is sometimes odd in the spreadsheet such as having trailing zeros or just any number of extra characters (normally 8000+ rows). So question being is there a way to do a "Loose match" on the fields to come up with a match? Thanks!
Best answer by takashi
