On the other hand, it seems you're looking for a dynamic setup using advanced schema contructing. Here is good starting documentation: https://knowledge.safe.com/articles/43899/dynamic-workflows-advanced-example-modifying-the-s.html and https://s3.amazonaws.com/gitbook/Desktop-Advanced-2016/DesktopAdvanced4AdvancedRW/4.15.AdvancedDynamicSchemas.html
You will have to use a dynamic feature type on the reader, and "Schema from first Feature" as schemasource. Using for example an AttributeCreator you can define your attribute types in the attribute{}.fme_data_type and attribute{}.name array and write them to the dynamic writer, which write the correct data types.
That wouldn't fix my problem, however, that seems to be fixed in fme 2017.
Generate lines out of points 4 Answers
Merge values of two columns 2 Answers
Filter by attribute names 4 Answers
What do fme_dataset, fme_basename, and fme_feature_type values provide for various formats 1 Answer
create table from attribute .json 5 Answers
