Best answer by david_r
Green Builing XML doesn't seem to be directly supported: http://www.safe.com/fme/format-search/#search=xml
On the other hand, there are a good number of functions in FME that should make it possible to support the most basic object types without too much effort, I guess.
Some starting points:
- https://knowledge.safe.com/articles/How_To/Reading-XML
- https://knowledge.safe.com/articles/Samples_and_Demos/Reading-Complex-XML-or-GML-using-XfMap
- https://knowledge.safe.com/articles/Samples_and_Demos/Reading-Complex-XML-or-GML-using-the-XMLFlattener
David
Take a look at this custom reader posted to FMEHub: https://hub.safe.com/formats/green-building-xml-gbxml
