I'm trying to use AreaBuilder to build a polygon that will be written to my existing feature class in a file geodatabase. The lines supplied to the AreaBulder have all the correct attributes but the attributes are not showing in the output of the AreaBuilder; just the polygon.
The AreaBuilder docs have a description of the 'Polygon List Name' parameter that states: 'This parameter can also be used to preserve attributes from input features.' But it doesn't explain how to do that. As a newcomer, I need all the help I can get. :-)
Could one of you please point me in the right direction? How do I use the Polygon List Name to preserve attributes?
TIA
B
