Topic | Size | Advantage |
Widescreen | S | Readability when attaching images! |
Give a notification when someone replies to a post you replied to (not only posts that you have posted to) | M | More activity! |
Make it possible to store upload an image (instead of using an online image-service that will remove the image after for instance 14 days) - Use FME to download the image and store in Safes own DB. | XL | No broken images! |
Possible to upload workspaces and download them directly | L | Huge bank with workspaces! |
Get the number of replies on each post when using the search | M | See empty questions! |
You can "only" go 10 pages backwards on the search | S | Find older posts on a topic |
Edit-post | M | Correct errors |
Topic | Advantage |
Widescreen | Readability when attaching images! |
Give a notification when someone replies to a post you replied to (not only posts that you have posted to) | More activity! |
Make it possible to store upload an image (instead of using an online image-service that will remove the image after for instance 14 days) - Use FME to download the image and store in Safes own DB. | No broken images! |
Possible to upload workspaces and download them directly | Huge bank with workspaces! |
Get the number of replies on each post when using the search | See empty questions! |
You can "only" go 10 pages backwards on the search | Find older posts on a topic |
Edit-post | Correct errors |
Search button 0 Answers
Water body into LnadXML 0 Answers
LiDAR .las files 1 Answer
FME workspace versioning system 1 Answer
HTTPSConnectionPool 0 Answers
