Shapefile fieldnames - ALWAYS UPPERCASE?
Hi just wondering if you can write shapefiles with mixed case fieldnames? I understand the issue probably lies with the underlying DBF structure, but the shapefile reader acknowledges the case just not the shapefile writer. Am I missing something or is there a way to stop all fieldnames being UPPERCASE?
When adding SHP writer on your workspace, open Parameters dialog box and uncheck "Use Upper Case" check box.
