http://www.openheatmap.com/
I have about 20 million points and I would like to show where the hotspots are.
One way it could potentially be done is to:
Or of course, you could try to create a DEM via the DEMGenerator. If you set it up right, I'm sure it would look spectacular!
Several posts and workspaces related to this online. And it can be done quite generic!:
http://fmepedia.safe.com/articles/Samples_and_Demos/Calculate-Density-or-Cluster-Analysis-Modeling
and
https://groups.google.com/forum/?fromgroups#!topic/fmetalk/aNORbVpiRgI
On the relevant forum (R) there are multiple examples to clustering techniques and heat map generation.
I idd adapted the surface builder method and use standard Gaussian calculation for hotspot generation. Picture shows surface building, generalizer and then rebuilding surface (to make it look nice)
Gradient building and gradient bar use same calculations, just different transformers.
Table created with same values etc. (table unreadable in pic ass actual map is large 300dpi A0)
Map was created using Mapnick Rasterizer (With a lot of sweat !) 26min runtime.
Trying the R caller recently to see how it fairs.
