The problem I run up against is I can't figure out how to set up which field to use for the text label. I have a field call TEXT_FIELD and I want each layer to use a different field from it's table as the label field. I want to use labelPointReplacer to look at the table and use the field of the value in the TEXT_FIELD.
So for example for the layer address points I want it to use the field ADDRESS_LABEL and for Roads I want it to use the field STREET. I have those listed in the TEXT_FIELD but it just labels them with the text "STREET" and "ADDRESS_LABEL"
Ideally I would like some of them to be more complex but allow me to add the label string in the table similar to something like:
"GENPLAN:" & [GENPLAN] & "- SECTION " & [SECTION_NO]
Any suggestions?
