Regards,
Hani
Regards,
Hani
In short, Static Schema is a fixed schema configured when creating the workspace; Dynamic Schema is a schema which would be dynamically configured at run-time based on a resource (schema of the source dataset in many cases).
There are many related articles in the Knowledge Base. I think these articles would be a good starting point.
Q&A: What is a Dynamic Schema? (http://fmepedia.safe.com/articles/FAQ/Q-A-What-is-a-Dynamic-Schema)
Dynamic Schema Examples (http://fmepedia.safe.com/articles/Samples_and_Demos/Dynamic-Schema-Examples-FME2011)
Takashi
