Can you read both before and after datasets into the FME Data Inspector, then look at the attributes and geometry in the feature information window? That might give you a clue as to what is different in the output.
Thanks Mark,
I have had a good look and cannot see any differences between the features.
Then I'd suggest sending that into the support team (safe.com/support) including the data and workspace and asking them for assistance. There must be some difference but I'm afraid I don't know off hand what it could be.
I understand this is an old topic, but for documentation: Adding the AppearanceRemover solved my problem.
I'm sorry to say that I don't have an answer to this problem, instead I have the exact same problem. The output between geodatabases (file, personal, and sde) are pitch black multipatches (that stay black even after exporting to other formats like Sketchup). Running the GeometryValidator does not fix the data. Writing to shape-format works, however... Where you able to find a solution for this, or did you figure out what the problem is @jackyd?
Oh, try the GeometryValidator - it might be able to detect bad normals or missing texture coordinates. Not certain it will help, but worth checking it out.
