Best answer by conterrauta
View originalUnsupported font family message
you can set the true-type-font directory in the parameters of the writer.
If you set this to the c:\\windows\\fonts folder you get the correct results.
Kind regards
Uta
The writer had some problems reading many some of the fonts in my C:\\windows\\fonts folder and was slowing down the processing as it was writing to the log. As a result I just copied a needed subset of the fonts into a different folder and pointed the writer to it.
How does this work for FME Server/Cloud?
@jdh009 Did you get an answer for this for FME Server Cloud?
Hi @deanhowell,
This is a fairly old Q&A here, would you be open to posting a new question to the Forums and perhaps link it to this Q&A for context? It will have much better visibility and gather more answers.
Off the top of my head, I would expect the desktop answer to work for server as well. It might be good to give it a try as well to see. Thanks!
Hi @jovitaatsafe, this could be related to an outstanding problem - C102087: PDF writer cannot write Text features containing Japanese characters correctly (PR#60358). Is it progressing to fix?
Hi @takashi, oops this is a little embarrassing on our side. You are absolutely right, there is a bug report [FMEENGINE-37316] outstanding on the issue where setting the font type returns a warning about reverting to Helvetica.
I have made a note in the issue that users have been asking for it, and I will update this Q&A when the issue has been resolved. Thank you takashi for bringing this up! (@deanhowell)
