Where is the Insert Constant tool?
  • 2 November 2015
  • 12 views
Badge +11
There used to be a functionality that you could add a constant on the workbench and connect it to a field in the writer and it would be added as a value to that field. Has that been replaced by a transformer? If so, what?
Hi
Right-click on the writer attribute and select "Edit value..."
After
Personally, I prefer using an AttributeCreator (or the like), though.
David
