I am converting ESRI shape files into the Norwegian national spatial data format, SOSI. SOSI is very strict on overlapping geometry, double or unconnected nodes and double lines in polygon features.
I am new to FME, so I need a little help in figuring out how to collapse double vertices, how to remove "blind" nodes (nodes that are unconnected) and remove double line features in polygons.
Any suggestions?
Chris
