Hello, I'm new to FME and have a workbench that does a dgn to ArcSDE geodatabase (SQL Server) feature class conversion of points. I have the "drop table" set to "yes" which I assume deletes all the features in the SDE geodatabase before writing to it. To that end, when I run the workbench, I get the error below. I can see that the geodatabase has locks from ArcGIS Server (we have three instances of ArcGIS Servers running). I would have to manually stop each ArcGIS Server instance before running the workbench to get it to run correctly. Is there a better way to run the workbench and update the data?
Unable to drop the table/feature class 'Bollard'. The error number from ArcObjects is: '-2147215875'. The error message from ArcObjects is: {Table is already locked [aoc_gis.GISADMIN.Bollard]}
A fatal error has occurred. Check the logfile above for details.
Thank you
Steve
