workspacerunner keep parameters
  • 29 June 2020
  • 1 view
Badge +1
Hello!
I have 2 workspaces. The second workspace call the first with a workspace runner.
The user of the workspace will launch only a .fme file. So for the moment, I use published parameters to fill the parameters on the workspace runner. But it's very long and if I update the first workspace I have to change the second one.
So there is a way to show the parameters of the workspace runner directly on the form when the workbench run ?
Thanks!
Badge +14
Is it possible for you to run the process (as an *.fmw) but via the 'Quick Translator' application instead? You can then avoid Workbench all together. It'll mean you can avoid the detail of the workspace opening to the end user and you can even password protect the workspaces to be sure. The main benefit is that the parameter form will launch right when you open the trigger workspace.
