Dynamically constructing WFS XML query
Badge +26
I'm constructing an XML query for a WFS service by using an XMLTemplater. The ROOT element is this:
<Filter>
<Or>
{fme:process-features("SUB")}
</Or>
</Filter>
And the SUB element, per feature, is this
<PropertyIsEqualTo><PropertyName>identificatie</PropertyName><Literal>{fme:get-attribute("bag_vbo_id")}</Literal></PropertyIsEqualTo>
Store in an attribute then use that feature to trigger a FeatureReader and use the query attribute. This works fine and results in a working query. Except when there's only one feature, in that case the WFS service seems to bork about the unnecessary <Or> </Or> tags.
My workaround:
  1. StringSearcher to count the number of times </PropertyIsEqualTo> occurs (i.e. the number of sub elements)
  2. ListElementCounter on the list of matches
  3. TestFilter to test for the number of elements
  4. If 1 StringReplacer to replace the <Or> and </Or> with empty strings
I can't help but think there's got to be an easier way to do this... I could combine steps 3 and 4 in one conditional value, saving me one transformer, but it still amounts to the same thing really. Any other suggestions?
Badge +16
Hoi @redgeographics,
Would the BAG API be an option? I usually use that and not the WFS service.
Badge +26
I am actually using that later on in the process, it's certainly worth looking into but I'm not sure how well it will work when you need to query a few hundred features.
The irony is that the chance of my user ever querying just one feature is very small, but I can't have the workbench fail on that of course.
Badge +16
I don't see the problem with querying a couple of hundred records (just did that for a client with a few thousands queries)
Userlevel 1
Badge +21
Can you do something like in the root element?
<Filter>
let $sub :={
return if (1 < fn:count($sub/Literal))
then <Or>{$sub}</Or>
else {$sub}
</Filter>
Badge +26
<Filter>
let $sub :={
else {$sub}
</Filter>
Yes, that does the trick, thanks!
