Attribute Data Type Preservation in FME 2020
  • 17 April 2020
  • 9 replies
  • 7 views
Userlevel 4
Badge +26
Hello FME users,
I just wanted to share some information about an update to data types in FME2020, which I don't think has been publicized much. The best demonstration is through a video, but first here's a brief description of the update...
In previous versions of FME, attribute data type would not be preserved fully throughout a workspace. For example, a writer could not determine the data type of an attribute added or edited in the workspace.
You could prove this by following these steps:
  • Open FME Workbench 2019
  • Add a writer and set the feature type attributes to automatic
  • Add an AreaCalculator transformer connected to the writer
The result is that _area is added to the writer, as type char(200). The writer was not able to tell that this attribute should be a numeric type. You would often see char(200) fields as a default for unknown types.
In FME 2020 this has changed.
If you repeated the above step in FME 2020, the result would be a real64 field (or the equivalent of that for the format being used).
In short, data types are now better preserved throughout a workspace.
Video Demonstration
Here's a video demonstration of the improved functionality in FME 2020
Note: If you don't see the video above, it's attached here:
Summary
I hope you find this of use. You don't need to change any settings to apply this; you'll just find that FME is doing a better job at handling data types throughout a workspace.
Badge +3
That's a nice improvement @mark2atsafe . I also found that previously simply renaming an Attribute also caused issues so I'm guessing that is handled as well?
Badge +16
indeed a great addition @mark2atsafe, does it also apply to automatic attribute definition?
Userlevel 4
Badge +26
Yes, absolutely.
Userlevel 4
Badge +26
I think so, yes.
Badge +6
Nice to see this feature @mark2atsafe. But it looks like Attribute field 'Names' are not being preserved (truncated when compared with Geodb reader) in shapefile writer for few of the attributes. Any thoughts on this?
Badge +3
Many Destination formats can't support particular Field Name formats, Shape files and the associated dBase files being notable examples due to their ~40 year old architecture.
That isn't a limitation on FME but a limitation of the Writer Destination Format.
Badge +16
I think so, yes.
Yes! can confirm that it does.
Userlevel 4
Badge +26
Yes, as @bwn mentions, Shapefile - because it uses dBase - has a field name length limit of 10 characters. FME automatically truncates names where necessary to fit this requirement.
That is, indeed, an appropriate and convenient change, but I find that it is not actually fixed, at least in my installation of FME 2020.1 Desktop Professional. Now, there may be a patch or the like that didn't get installed in my case, or, after my Windows Profile meltdown and rebuild a few weeks ago, that was "lost track of" in some way. I don't know; however, my 2020.1 is still dropping the attribute type info on write. ( ... and yes, I can and do make the very easy changes necessary by switching User Attributes in the writer to Manual and changing the attribute types there.)
