Hi community! I'm unsure how to tackle this so looking for any suggestions...
What I have is a data set of hundreds of points. These are arranged in 'groups' by sharing a common attribute. I'd like to join point to point (create lines) in every permutation of each group. See example images of groups below.
My ultimate objective here is only to find the longest distance (and generate a line) between the points per group. Bear in mind that there are multiple groups so I need to run the operation by group or have another means of performing the analysis per group. This is a 2D exercise however the points have a Z value that I would like to retain. Thoughts?
