Generating date and time columns
  • 20 February 2020
  • 18 views
Hi there,
I want to create two columns: One column generates the dates between two given dates and second column contains the half an hourly time stamp of each date. For example:
Column AColumn B1/1/202000:001/1/202000:301/1/202001:001/1/202001:301/1/202002:00............................................1/1/202023:302/1/202000:00
So that means each date of column A would have 48 values (half an hour slot) of column B. Could you some one tell me how to do that in FME?
Userlevel 2
Badge +16
That was a fun challenge.
I created this workspace that takes a start date and a number of days and creates the shown output:
The workspace can be found here: Date_Time_intervals.fmw
Hope this helps.
