I have two datasets which need to joined. Both datasets store the attributes 'CI_nummer' (numeric) and 'NaamObject'. An example value of the last looks like: ZN VKS MSI A16L 46,935 1
I want to join the datasets if both these attributes match. . Beside this, the NaamObject also needs to match for a certain minimum of characters.
46,935 these numbers represent a distance value. 46 kilometres and 935 meters.
When the difference between two distance values (dataset A versus B) is less than 500 meters I want FME to see these values as identical. For example:
These two values should be considered as identical:
ZN VKS MSI A16L 46,835 3
ZN VKS MSI A16L 47,122 3
These two values should not be considered as identical
ZN VKS MSI A16L 48,122 3
I am thinking about something with a regular expression? Any ideas how to solve this issue?
Â
Â
Â
Best answer by ebygomm
