Hoping someone can help with this. Since upgrading to 2019.2 our existing workbenches have begun to fail. Each time a coordinate system is called on it appears to be missing a curly brace at the end.
E.g. "{EPSG:27700 is not a valid key name." or
"{OSGB-GPS-2015 is not a valid key name.
... Last line repeated 11 times ..."
These are only warnings until eventually the workbench fails under:
"No definition was found for coordinate system `{EPSG:27700' "
Wondering if this is a bug or if we are missing something?
Let me know if I need to provide more info.
Best answer by mark2atsafe
