Hi - Does anyone have some pointers on how to handle special characters in layer names against ArcGIS Online when using the in-built writers?
e.g. I have a layer on ArcGIS Online called Layer 1 (Addressing)
FME changes this to Layer 1 _Addressing_ which in-turn will cause the transformation to fail.
How does one handle this without changing the layer name as it has to be be this.
