My target ESRI File Geodatabase (FGDB) is following UPDM 2019 data model. By that, we have few feature classes which contain many subtypes. Many feature class attributes have defined default values on the level of the FCL subtype (AssetGroup) usually in combination with domain.
What I noted is that default value of the attributes not contained in the FGDB writer is not populated in the target FCL. We have huge number of attributes on the FCL level and it would be quite some work to pick up each default value and set it up in the writer. Maintaining such workbench would be also quite demanding.
Can someone please tell me is it possible to get somehow the default value of the attribute automatically populated in the FGDB like when manual editing in ArcGIS Pro? I am using FME 2019.2 with ArcGIS Pro 2.4.
Thanks in advance,
Dušan
Â
Â
