I have made a workspace which is used to map geometric errors. My data is stored in the gml-format.
In my workspace I have a FeatureReader, which reads GML data. Issues in my source data can be among other things:
- Consecutive vertices in lines or polygons
- Too many coordinates in my point elements
- Non-closing polygons (last vertex isn’t the same as the starting vertex)
The problem I have with my gml FeatureReader is that these errors are fixed automatically by FME. The consecutive points are removed, the last coordinate of my point element is used and my polygon is closed automatically by adding the first vertex as last coordinate. This is convenient when I want to work with the data without hassle, but in this case I want to know what those issues are so I can correct my source data or report errors.
Is there any way to show the errors corrected by the FME reader or prevent the reader by doing so?
