I'm trying to demonstrate how FME (eventually FME Server) can automate a process for us. I have all of my NMEA data in one folder (they are stored by day in a given month; hence, there can be 700-800 NMEA files in each folder), and I can get the reader to read them all manually...but I would like to know if it's possible to get FMEWorkspaceRunner to automatically read and load all of the files in a folder that will then be converted.
The FMEWorkspaceRunner variable is set to: runner = fmeobjects.FMEWorkspaceRunner()
I tried to be sneaky and use parameters['SourceDataset_NMEA'] ='\\\\2018ais\\c$\\rawnema\\Feb2019\\*.nmea', but it did not work using runner.runWithParameters(workspace, parameters).
I can (of course) do it manually from Python by using runner.promptRun(workspace), but this then defeats the purpose of my Python script.
Is there a way to get the FMEWorkspace Runner to automatically read/load all of the files in a folder that will then be converted?
When loading all of the NMEA files manually from within the FMW it works perfectly, and converts all of the points directly into a file geodatabase.
Best answer by ryanatsafe
