it's possible insert 2 file, 1 ecxel and 1 dwg file in the welcome page?
if it'spossible can you help us how do it?
@managementsw Can you please expand on your question? It's not clear what you mean by the welcome page.
If you're new to FME then I recommend you contact your FME supplier for introductory training or you can use the on-line training resources for getting started with FME. In particular Introduction to FME Desktop 2019.
But if you're looking to combine data from an excel and a dwg file, just start by dragging the files onto the workbench canvas.
Ciao @managementsw as I understood you are following an FME Desktop tutorial. My suggestion in this first step is to follow the instruction as is. At the end you will have a complete workspace where you can add files as you needs.
If you need help feel free to contact us here https://www.genegis.net/fme-team
in the attach, in the file kme.zip there is the word with the page where we want add the 2 file, can you see in sample-data file in the page "getting started exercisies"
thanks
FME on linux 1 Answer
Having trouble installing FME Desktop 1 Answer
Error code 2330 when installing FME 2017.1 2 Answers
FuzzyStringCompare 4 Answers
