How to change from "point" to "linestring" in XML to GeoJSON conversion?
  • 18 November 2019
  • 10 views
Hi, I'm converting a file from XML to GeoJSON. The conversion goes fine, but I want the coordinates to be in a line ("geometry":{"type":"LineString"...). I'm somewhat new to FME Workbench and can't figure out how to do it in the conversion, is it possible?
