I am running an AnchoredSnapper transformer to snap lines to vertexes. after the operation is complete all the lines previous attributes are intact, however when exported to a shapefile the attribute names and values are truncated to one character. I've tried the default attribute definitions as well as played around with the string type and mapped each individual attribute with no luck.
hi @sjsharron, are you using the 'tech preview' shapefile-exporter?
I reported the same issue today, you can look at @mark2atsafe 's remarks and solutions here
and i don't have the issue when using the 'classic' shp exporter, maybe that one can help you for now?
