Hİ Everyone,
According to Excele, I want to create a folder according to the data in cells A, B, C.
Then according to the cell d in Excel, I want to send the tif under the folders that have been created.
How can I do ?
Hi @orayozyigit, if I understand your requirement correctly, this could be a possible way.
See also the screenshots below. Assuming that a user parameter called "TIF_FOLDER" stores the Tif folder path.
Feature Type of the File Copy Writer
Fanout Expression for the File Copy Writer
Reading multiple shp files from sub folders 1 Answer
FME loosing touch with folders 2 Answers
Location templates in 2018 not under Shared FME folders 3 Answers
How to filter raster spread across many folders 1 Answer
Understanding relative paths 1 Answer
