I need to add 26 points from 2 different shapefiles into an existing point feature class stored in an SDE. For the destination features, the "enclosureid" values should be equal to the automatically generated OBJECTID's
That said, ESRI recommends not using the OBJECTID value for basically anything meaningful.
unable to read shape file with ESRI SHAPE Reader 4 Answers
Esri SDE writer: How to use it compatible for SDE/Oracle and SDE/Postgresql 2 Answers
shapefile FID field 1 Answer
How to circumvent geometry errors using the SDE Writer? 1 Answer
'Drop and Create' on SDE Feature Class with Attachments deletes the attachments 2 Answers
