How to define permissible values of an "Enumerated value" Property Typ of the IFCPropertySetDefinitionCreator
  • 25 October 2019
  • 4 views
i like to define the permissible values for attributs with Property Type = "Enumerated Value" defined with the IFCPropertySetDefinitionCreator. (see below)
How to set a liste of permissible values for the PropertyType "Bounded Value" ?
Is it possible to set de upper and lowerBound with FME?
The definition of the attribute value is already defined by using the attribute creator. (see below)
Test_Attribut_21 = 'Testwert 21'
Best regards
LuHu
Badge +21
Can you use an AttributeValidator to do the validation before Writing?
right, for checking the values.
But
i like to define the permissible values in the IFC-file/IFC-schema.
