Merge attributes from Spatial Join
  • 14 October 2019
  • 6 views
Intersecting some points with polygon features, there are multiple points per polygon. The trouble I'm having is I'd like to have a delimiter separated summary of an attribute from the joined points. As an example, three points might intersect one polygon (they have ID values 1,2 and 3).
The desired output would be polygon geometry with a field called Summary ID and a value of "1;2;3" for that polygon.
Does anyone know of a transformer that might handle this attribute merge?
Userlevel 1
Badge +21
If you use a point on area overlayer, and choose to generate a list on output 'area' under attribute accumulation, you can select the point id you want added to the list. Then use a list concatenator on the output of the area port to create the summary Id field
